Fault codes for MF 6245
   / Fault codes for MF 6245 #1
Johnyboywithdog71
Massey Ferguson 6245
Hello, I致e been trying to fix my parents 3 point linkage problem on their 6245 Massey Ferguson but have ran out of ideas. The rest of the hydraulic system works fine, as in the front end loader, and the PTO is fine. In fact all other operating functions work fine. After eliminating some possible causes it seems to be a fault code problem. The knob that lifts the 3 way has a red warning light that is permanently on. It was flashing a 2-4 sequence but now it is just staying lit with no flashing at all. The farm machinery businesses haven稚 been very helpful and 2 tractor mechanics that have called out both couldn稚 help, but were happy to take my money regardless. I would be grateful if anyone could suggest something for me to try and I am happy to pay. I just desperately want to get it fixed as it痴 fire season and the meadow grass is high. Thanks. Lincoln.
Edit: so the 3 way linkage does not function at all. It’s a 3 way switch.
   / Fault codes for MF 6245 #2
This is a really really long shot, but since the manual and mechanics can’t help, it’s certainly something to try - just disconnect the battery for a few minutes to see if that resets the codes. Also make sure the battery is fully charged (and the alternator is working) in case minor voltage drops are part of the cause. Is a simple thing yo check at least; you never know.
JOHN DEERE HPX GATOR 4x4 *NOT RUNNING* (A50324)
JOHN DEERE HPX...
Poly Round Bale Ring (A50515)
Poly Round Bale...
2018 Gatormade 20+5 Gooseneck Trailer (A52748)
2018 Gatormade...
2017 Ford F-550 4x4 Enclosed Utility/Air Compressor Truck, VIN # 1FDUF5HT6HED32921 (A51572)
2017 Ford F-550...
KJ 20'x12' Livestock Metal Shed (A50121)
KJ 20'x12'...
2014 Peterbilt 384 T/A Day Cab Truck Tractor (A51692)
2014 Peterbilt 384...
