Fastest growing anything...help
/ Fastest growing anything...help #1
CTyler
Veteran Member
Blair, Ne.
L3130
The recent rains and the severe storm this weekend have caused me much grief again. My grass was starting to grow everwhere and now I have large areas that are wiped out.
I have two recurring problems.
1. The water that run around the house keeps rutting and
wiping out the grass and roots everytime it gets started.
I'll be fixing this for the third time this weekend.
2. I have a waterway that I fixed several times last year.
Fixed it again a few weeks ago and had grass started on it
and now its' wiped out again.
The problem with number 2 is the 30"+ culvert that goes under the county road. When it rains hard there is a lot of water coming out of it. Then it wipes out the dirt and piles it in my terrace. /forums/images/graemlins/mad.gif I've been putting 6'+ flat bottom on it.
So what can I plant that will grow overnight? I don't care if I have to buy weeds!! I'm going to talk to the seed dealer this afternoon and see what they have for mesh material as well.
/ Fastest growing anything...help #2
Straw or hey strolled around should holp some. Unroll some round bails where you can for good results. I have also learned the hard way a couple times a year that water is the boss! Seams like it dont just rain anymore. Its a full blown FLOATER or nuthin. Silt fence is great but you realy have to want it $$$$$. good luck.
/ Fastest growing anything...help #3
The county just recently took a grade-all and re-ditched a section of the roadside. They used a cloth/fiber type material that was tacked down on the fresh dirt.. to prevent washout while the grass regrew. I saw the same type of matted material at the tractor supply store yesterday.. grass seed is embedded w/in the material.. maybe this would help.
I did the straw thing everytime I fixed that waterway last year. Was ready to cry after the third time.
Slit fence...LOL...I can laugh at this now. Learned my lesson on that. Use metal T posts. Those 2x2 stakes all snapped like little twigs.
Hopefully the mesh/fabric is fairly inexpensive. However at this point I don't think it matters what it costs. Probably should have started with something like that to begin with.
/ Fastest growing anything...help #6
Having gone through the same experience, I can feel your pain /forums/images/graemlins/frown.gif. Are you using annual rye in your grass seed mix? Annual rye will germinate more quickly and help hold things in place while the other seed germinates. Generally a 20 to 30 percent ratio of annual is sufficient. I found a "straw mat" at a local seed dealer. Around here, this is used by the hiway dept. on ditches and hills. This straw mat is a thin layer of straw sandwiched between 2 layers of mesh. After you seed, you just roll the straw mat out over the area you need to protect. Get some sod staples and peg it down around the edges. This stuff worked great for me even with a couple of heavy rains. I paid $45.00 per 8' X 120' roll. A little pricey if you have much to cover. Also, don't forget to sow that ditch a little heavy to help prevent washout in the future /forums/images/graemlins/wink.gif. I wish you the best of luck.
/ Fastest growing anything...help #8
Do you have 4" ABS Corrugated Black Draintile running from your gutters? (you do have gutters, don't you?).
Last fall I worked on 30,000 sq feet around the farmhouse, and tilled, "Harley-raked", fertilized and spread an annual ryegrass/perenial ryegrass mix. I had the local landscape company come and shoot hydromulch over the whole area (they used the hydroseed mix but didn't use the seed.) The ryegrass started sprouting in 3-4 days, despite the very dry fall in Michigan. The mulch lasted the entire winter and I didn't have any erosion problems. The price was $450 per 15,000 sq feet. You might even consider having the area hydroseeded or sodded.
As for your second culvert problem I can't tell from your description, but it sounds like you may be trying to keep something that is impossible. Water always wins - it may take time, but it always wins.
Went down to the seed dealer. Bought a 5x216' mesh roll, 100 sod stakes and a 50lb bag of annual rye. $190 for it all, Kinda spendy.
I've been using a fescue blend, called non-destruct II, with some annual rye in it. I'm going to use that and put down extra rye as well.
The sod idea crossed my mind but I'd need 700' hose to water the waterway in the terrace. A strip of Sod could work down the side of the house though.
Yep, I have gutters /forums/images/graemlins/laugh.gif. I even dug french drains for every one of them. They worked well even with this last horrible storm. They do not contribute to the problem.
The area on the side of the house isn't that bad. There is a lot of area that has to drain to the north side of the house though. It all collects together once it gets to the north side. Since its' on a slope it speeds up. Every time the grass start going it rains enough to create a rut aprox 1'+ wide a few inches deep. Not counting this last mess. It will be fine if I can get the grass past the fuzz stage.
As far as the waterway from the road to the terrace. This will probably be my last or next to last attempt. After that it gets riprap.
/ Fastest growing anything...help #11
have had the same problem with a 1' culvert up the (deadend road) street from me and went up and blocked it up completely...they put in the culvert a few years b4 i move here but allows ALL the water from the hill above me to wash right onto and thru the property..b.s i said..even asked the town garage maint. mgr bout it and he jist smiled and ssiad he didn't care bout blockin it up..would like to eventually use all that water after i build a pond... /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif now the water runs down the high side of the road opposite my house and down into the woods...
not sayin u could but what would happen if the culvert were somehow blocked up??? would the water do any damage downstream somewhere or would it wash something out??
just food for thought?????? if some ojne trys to unplug mine b4 i git the pond built...therre's gonna b a can of extruded foam with a string round it thrown into the middle with a couple holes in it ...let it go in and empty and then pull the can out...permaplug!!! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
a whellbarrow load of sticks and leaves raked in front would give u some time to let yer stuff germinate as long as the water isn't going to do any damage somewhere!!!
go talk to the road maintenance guys as they are responsible for properety damage caused by runoff ...But if u follow the runoff possibilities if plugged and nothing will happen i'd jist try to block it temporarily and not say a word ...be careful and use good judgement...make sure that you use sticks from the same type of trees that are above the pipe..not "pines from yer yard" so to say.... and no fresh chainsaw cuts!!! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/wink.gif
Believe me I thought about blocking it...LOL!! Have gone an looked at it several times. Trouble is there are acres of pasture than drain into it. There is an area that would hold a fair amount of water but if it were to fill up it would run across the gravel road. A moderate-to heavy rain would fill it up and create more problems that it solves. /forums/images/graemlins/frown.gif
/ Fastest growing anything...help #13
any way to do a combination : block half and then divert it using culvert pipe tjo git it away from yer project and to b honest with you i'd ( from the sounds of the quantity that runs thru...) i'd build a culvert diversion system maybe using rock or sumfn or how bout a pond...why cant u send us pics...i wish everyone would send more pics in the beginning and then we would havea better idea of what we are talkin bout!!
/forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
I'll try to remember to take some pics tonight. Told myself to take some pics last night then forgot about it.
Here is a pic of the waterway. There is a culvert at the top you can't see, its right where the tree is. You can see the area that drains into the culvert on the other side of the road.
That dirt area on the bank was where the county dumped a bunch of road gravel and dirt. There was grass there before they did that months ago. I never saw a slide or anything, not sure what the deal was with that.
Close up of the waterway.
Here is mud in the terrace
This is the area in front of the shop that got wiped. Notice that the grass at the top was established a little better and is ok. This is the first time for this area since it was planted a month ago. This was due to our latest storm, a really bad one. Once this gets established it will be fine.
Here is the front yard of my house. Your looking toward the area that is drains toward and around the side of the house.
Closer pic of the front where the water starts collecting and washing out the new grass. This area shown hasn't been bad.
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2012 WIDLCAT 5th WHEEL CAMPER (A60736)
2012 WIDLCAT 5th...
2013 Mack Granite GU713 Quad Dump (A62613)
2013 Mack Granite...
2020 DRAGON ESP 150BBL ALUMINUM (A60736)
2020 DRAGON ESP...
IRANCH SEMI-AUTOMATIC QUICK CHANGER (A60736)
IRANCH...
