FarmTrack 555 DTC Hard to shift into gear
   / FarmTrack 555 DTC Hard to shift into gear #1
PatBenkert
Muskegon, MI.
FarmTrack 555 DTC
My Transmission is getting harder to shift into gears. Sometimes the gears line up and then other times you have to let the clutch out and push it back in while holding slight pressure on the shifter. You can feel the gears slowing down and then they sync up and it will drop into gear. I do not want to grind them so i am trying to be careful. It seems after 30 minutes when things heat up it get worse. I have tried double clutching but that only helps once in a while. I have been thinking of putting an lubricant additive in the transmission. Has else had this problem? Any help would be appreciated.
10' Unused Feed Bunk (A50515)
10' Unused Feed...
300-gal Poly Sprayer 60ft Boom (A52128)
300-gal Poly...
(1) 250 GALLON POLY TOTE W/ CAGE (A51244)
(1) 250 GALLON...
UNUSED FUTURE MINI EXCAVATOR COUPLER (A51244)
UNUSED FUTURE MINI...
TMA (A49461)
TMA (A49461)
2021 International HV507 12ft Dump Truck (A51692)
2021 International...
