Oil & Fuel Farmtrac hydraulic-transmission fluid
   / Farmtrac hydraulic-transmission fluid #1
marhar
Denton NC
Farm Trac 60
Fellows, I have been working on my Fathers Farmtrac 60. It has not ran much in the last few years. The oil change is straight forward. My question: I assume the hydraulic and the transmission fluid are the same thing. That is there is one filter and there is one place to add; am I correct?
   / Farmtrac hydraulic-transmission fluid #2
Better late than never, buy yes to all
   / Farmtrac hydraulic-transmission fluid #3
Gonna' bring up a old thread here on this subject.
My FT60 is a '98-'99 model with the flat fenders.
My operators manual says;
transmission ............ M2C86-B or M2C159-B
rear axle ................. same numbers.
My tractors transmission has its own fill and drain plug with a dip stick and manual says 24.3 pints.
The rear end has its fill plug on top and a check pug farther down the side and a drain plug on the bottom and holds 49.2 pints.
My old Farmtrac dealer sells Lubriguard hydraulic & transmission oil with the Ford M2C86-B number which I use in the rear axle as its supplies the 3 point and fel hydraulics.
He also says to use a 80w-90 gear oil in the transmission which foams out the vent hole in the fill plug when pushing 1700 rpm on a hot day after running a 6' Rhino for 2-3 hours in heavy fescu/Bermuda and red clover.
My question is would using the M2C86-B fluid help with the foaming out the vent hole in the filler plug ?? Any thoughts on the foaming issue. Is there a higher temp 80w-90 oil out here ??
JIM
   / Farmtrac hydraulic-transmission fluid #4
Why not just use what it calls for. The sames stuff that is in the rear end. That's what I run n my 555 which is basically your 60. If you are set on 80 90 you could try synthetic, but that would cost$$$. In the least look and see if the oil you are using has anti foaming agents in it. Foaming oil is bad as the presence of foam in a lubricant disrupts oil film and promotes wear.
   / Farmtrac hydraulic-transmission fluid #5
Yeah, I realize the M2C86B specs go in both. I've used different brands with the M2C86B specs but all seem to create foam above 1600-1800 rpm after 2-3 hours on a 90-100 hot day using my mower. I can drop rpms back below 1500-1600 and foaming stops.
Just sold 35 5x6 round bales so may use some of that monies invest in a synthetic oil.
Thanks.................Jim
   / Farmtrac hydraulic-transmission fluid #6
JIM
What is the model and serial number on your tractor. my tractor has the flat fenders and I can only find one dip stick and fill point. Farmtrac 60.
Mini Skid-Steer Stump Grinder (New/Unused) (A59225)
Mini Skid-Steer...
CHINESE 125 ATV (A54757)
CHINESE 125 ATV...
2020 Kia Soul SUV (A55973)
2020 Kia Soul SUV...
PALLET TOTE OF MISC PARTS (A58374)
PALLET TOTE OF...
2021 DORSEY 53FT FLATBED TRAILER (A58018)
2021 DORSEY 53FT...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A58018)
2019 INTERNATIONAL...
