farmtrac 35
   / farmtrac 35 #1
Michael 6
oxford, fl
maasey ferguson 20f
Ok, I need some help. I have a farmtrac 35 that the rear outer pto shaft seal was leaking. I took the shaft out (found why you drain first) took out the old seal and have been to every tractor store auto parts store and have spend hours online trying to find the seal. The seal that came out has a number on it (2 actually) neither comes up on a web search. The parts book shows part: ESL 12532, but that does not show up online either. The seal I can find online is an: ESL 10809, but that says internal seal. I am hoping someone here can point me in the right direction. I used a micrometer to get the dimensions: outer is:71.22 and inner:40.41.
Look forward to any help.
Thanks Michael
   / farmtrac 35 #2
I can't help you with the seal, but bearing specialty houses generally can match a seal. I found it is better to take it in to them. If you are in a more rural area that doesn't have such a business, maybe a phone call could give you some answers.
2019 Ford F-250 4x4 Crew Cab Pickup Truck (A50323)
2019 Ford F-250...
CATERPILLAR 259D3 SKID STEER (A50458)
CATERPILLAR 259D3...
10' Feed Bunk (A50515)
2016 Ford F-150 Ext. Cab Pickup Truck (A50323)
2016 Ford F-150...
SELLICK S80 STRAIGHT MAST FORKLIFT (A51242)
SELLICK S80...
