Farmtrac 320DTC turn signal
   / Farmtrac 320DTC turn signal #1
shadebaby
I have recently purchased a 320dtc and the turn signals do not work. I looked under the dash and I found a three prong plug with nothing to plug it into the plug comes from the switch on the steering colum. Does anyone know what I am missing??:confused: Thanks
   / Farmtrac 320DTC turn signal #2
My 390HST kept blowing fuses when I bought it and tried to use any of the lights coming from the turn switch. Turns out one of the wires under the dash rubbed against the frame until it exposed bare wire. There were several unused plugs from mine hanging under the dash. No idea what they are. Not sure if any of them went to the turn signal, but I don't believe so.
Check for another harness with the same wire colors that could plug into it. Only other thing I can figure is maybe it's not wired for turn signals?
   / Farmtrac 320DTC turn signal #3
My guess would be the flasher unit, probably get one at an auto parts store. As I recall, some of these tractors came in with a turn signal switch, but they didn't hook them up as turn signals are not a requirement in the USA, the 4 way flashers are, and when they are on, the turn signals don't work anyway.
   / Farmtrac 320DTC turn signal #4
I agree with bluechip. The turn signals never worked from the factory. The flasher unit never had the more expensive turn signal module to keep the price down on the tractor. LS version today is the 3010.
2019 PRINOTH PANTHER T14R CRAWLER (A51242)
2019 PRINOTH...
2019 BOBCAT S770 SKID STEER (A51242)
2019 BOBCAT S770...
2012 MITSUBISHI FUSO SINGLE AXLE DUMP TRUCK (A51222)
2012 MITSUBISHI...
New Power Line 400 Plastic 3pt. Spin Spreader (A50774)
New Power Line 400...
2014 PETERBILT 388 AUTO TRANSPORTER (A51222)
2014 PETERBILT 388...
EVERYTHING SOLD AS-IS WHERE IS!! (A50775)
EVERYTHING SOLD...
