Farmpro vs KAMA
   / Farmpro vs KAMA #1
Paddy
Veteran Member
Bloomington, IN
Kubota, G5200, KAMA 454
Any thoughts on comparring these two? I've been looking at the KAMA 454.
Patrick
   / Farmpro vs KAMA #2
Go for the KAMA (I'm just a little bias though) /forums/images/graemlins/grin.gif ... Scozz
   / Farmpro vs KAMA #3
Which model of Farm Pro. probably like comparing apples and oragnes. Assuming you are thinking Farm Pro 2430, the KM454 has a 50% HP advantage, constant mesh trans for easier shifting on the fly, wet disk brakes, hydraulic remotes, mechanical shuttle and about 500 more lbs of iron. It is a little more money though and it the 2430 will do what you want to do, then it may make sence for you.
   / Farmpro vs KAMA #4
I am also making a decision between the Kama and Farm Pro. The big pos I see for the Kama are the size, added HP, Shuttle Shift, Syc trany, and gauge cluster. The big pros on the Farm Pro is parts access and a 1 year Labor coverage. Also I see the fiberglass panels as a big pro.
Farm Pro's are obviously Jinma's and parts are available via online shopping and many dealers. I can not find any online catalog of Kama parts. I am also not sure of other Kama deals will sell parts for a tractor they did not sell if your dealer is out of stock. Anybody have any ideas on this?
I actually favor the Kamma but am still trying to get more educated on the parts issue before making a final decision.
S2kDaniel
   / Farmpro vs KAMA #5
s2kdaniel
If you want a 1yr labor guarantee your more than likely going to have to go with whatever is close to you. Either one of those tractors be prepared to get your hands dirty. If you do a search in this forum you'll find out that most repair work is done on the jinmas vs. kamas. I've only been in here less than a year and there's very few kama problems compared with jinmas.
From what I've seen kamas are somewhat newer than jinmas but month for month kamas seem to be prone to less wrenching time from the owners. I have one, took some research on my part but I spent the money, money I would say was well spent. As far as the parts issue, I've needed only minor parts and my dealer although out of state has always gotten me the parts (all of 3) within 3 business days.
   / Farmpro vs KAMA #6
There are a whole lot more Jinmas out there with a lot more hours than the Kamas. I'm not sure when the Kamas came out but I would say they are fairly new. I have seen posts from Jinma owners with up to 600 hrs on them with few problems. Some have had there share but many are dependable with the the little quirks that happen to all including the big three. Parts would be my question of which to buy. They will all need parts no matter what brand they are.........Any Kama owners out there lets hear how many hours you have on yours and what problems if any you have had.......Not a bash board just for everyones info.........
John
   / Farmpro vs KAMA #7
</font><font color="blue" class="small">( Any Kama owners out there lets hear how many hours you have on yours and what problems if any you have had )</font>
2004 KM454 with 70 hours
I understand that it's not exactly fair to measure a 25hp Jinma against the much larger and heavier 45hp KAMA. So don't anybody take this as Jinma bashing. And I'll qualify up front, that MANY of the Jinma maintenance problems were CAUSED by a dealer who was obviously unprepared to properly maintain what he sold.
After hundreds of maintenance hours put into a pair of JM254s, this KAMA is comparatively trouble free. There were a few "new tractor" bugs to work out in the first 20 hours or so. But nothing that a few warranty parts and regular hand tools couldn't fix. And once fixed, the problems STAYED fixed. Where the Jinmas were shop queens, this KAMA has only been laid up 2 hours - while I went into town to get a fuel line repaired. Even with no glow plugs, the engine has started every morning this winter. Fuel consumption seems reasonable for a 2.5 liter engine, seems like I go weeks on a 16 gallon tank. The hydraulic filter is (thankfully) external, but it's mounted so low as to require the reservior be drained before changing screens.
It's nice and wide, with a lower center of gravity than the Jinmas - but obviously can't turn around in a Jinma sized circle. Whereas a 25 hp Jinma turned out to be insufficient to my needs, I haven't come across a job around here yet, that 45 hp won't handle easily. I will say though, that the KAMA has wimpy TPH hardware; I've bent the all threaded ends already - toplink and both vertical stabilizers. Really really soft steel. I've already gone to Pat's Hitches on the lower lift arms, and am getting a hydraulic toplink next month (the KM454 has factory rear remotes). Now if I could only find some vertical stabilizers that fit............
//greg//
   / Farmpro vs KAMA #8
TS 354C (38hrs)
I dont think it would be fair to include mine since it sits on the side of my house for the time being. I bought it for our ranch in the north and its not there yet. When it was delivered I planed on going thru it top to bottom before we take it up there because we are pretty much cut off from the rest of civilization. Lets face it if there was a problem up there nobody would know because there's no phone or net service up there.
When it arrived there was very minor problems right off the bat, broken rear light, bad reverse switch then while I was on my driveway I noticed a trail of spots. Looking further I noticed the steering cylinder was leeking. So I replaced that, then changed the filters with aftermarket ones, changed all the fluids and getting ready to replace the radiator hose. Seems the american anti-freeze and chinese rubber dont mix. If it wasent for TBN I would be lost in more ways than one. On a side note GREG for us that dont know tractor jargen whats a TPH?
   / Farmpro vs KAMA #9
I would guess TPH stands for Three Point Hitch
   / Farmpro vs KAMA #10
There is absolutely NO way you can compare Kama and Jinma. Different class of tractors. Kamas begin where Jinma basically end(for now anyways).
There are many, many more Jinmas out there so of course you will hear of more defects and problems but with so very few Kamas it will take time to hear exactly what the issues will be. Issues and defects are a certainty with ANY brand equipment.
1998 Genie Z-45/22 Boom Lift (A52384)
1998 Genie Z-45/22...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2007 International 7500 sba Flatbed 6x6 Truck (A52384)
2007 International...
2019 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A51692)
2019 Ram 1500...
APPROX. (21) NEW 30' SPAN 4 1/2 TRUSSES (A51248)
APPROX. (21) NEW...
