FarmPro Voltage regulator wiring help
   / FarmPro Voltage regulator wiring help #1
SapperDan
FarmPro 2430
I recently got a Farm Pro 2430 tractor. The wiring is nearly all missing. I would like to add back a fuse box/voltage regulator but dont know where the wires go.
I bought a "New Style" fuse box with voltage Reg, flasher and horn relay all integrated. The voltage reg is marked FNBLE. Anyone have one of these regs? Can you tell me what wire goes to alt F, Battery +, ground, etc?
Thanks,
   / FarmPro Voltage regulator wiring help #2
Not sure on a Farm Pro but my Rhino started to have intermittent charging about 9 months ago .
After manually applying power to the field wire it charged.
I bought a generic 3 wire solid state " Chrysler" regulator.
Literally has +12V key on
a ground to tractor frame/ casting
and the F output goes to the Field wire on the alternator.
The original was identical in 3 connectors as well
Charges at 14.1 VDC Can't complain at under $13
If that is a recommended replacement for a Farm Pro it should have some info/ wiring diagram ?
You have to be careful on regulator replacements because some cars/tractors they do the regulation exactly opposite by applying 12 volts to one alternator brush and then the regulator varies the continuity with reference to ground to the other slip ring brush to maintain the desired voltage output on the alternator battery terminal.
2024 AGT KFE-20 2,000lb Electric Forklift (A50322)
2024 AGT KFE-20...
City of Lakeland (A51691)
City of Lakeland...
Satoh Beaver Tractor (RUNS) (A50774)
Satoh Beaver...
2020 KUBOTA RTV...
2017 John Deere 855D 4x4 Gator Utility Cart (A50322)
2017 John Deere...
Unused 2025 CFG MX12RX Mini Excavator (A50322)
Unused 2025 CFG...
