Farmpro 2430 low battery?
   / Farmpro 2430 low battery? #1
rickya
missouri
farmpro 2430
New user ,great site. Just bought a 2430 . Amp meter regersters 0. Batterys were half full. Then checked alternator,idle speed12.6volts,2000rpm 13.0 volts.It says its a14volt alternator. Is this normal. Thanks,Ricky
   / Farmpro 2430 low battery? #2
batteries may be pulling down the voltage, once they are fully charged you may see a higher reading. So long as the voltage is above 12V the batteries should charge. The voltage regulator is supposed to kick off at 14Volts.
   / Farmpro 2430 low battery? #3
Very very good chance that the ammeter is simply wired up wrong (or not at all), or simply defective.
My last Chinese battery had an internal short. Did you check specific gravity of all cells?
13V out of the alternator should charge a battery, but amperage is important too. Did you check that?
//greg//
   / Farmpro 2430 low battery? #4
Greg & BC: said it right:
if the battery is DOWN, then reading 12~13 volts when running is right on money. It will stay low untill battery gets charged up then voltage will start going UP untill it hits the 14 Volt mark or so then cut off for a few seconds then back on. as it charges & shuts down...
make sure to check battery voltage when fully charged (should be about 12.4 or so min voltage.) also you MAY have a volte meter that is off a bit...
keep us posted, make sure to check the small caps on the battery too. there was a rash of them which the little vent holes were not punched through, so the battery would not vent and builds pressure internally and can split a seam or blow acid out a seal... (had to use a pin/prick punch to push a small hole into about 4 of the 6 on mine...) a DART works very well /forums/images/graemlins/wink.gif
Mark M
   / Farmpro 2430 low battery? #5
If that battery has a bad/shorted cell.. it may not let the voltage come up... might check it with another battery.. like the one out of your truck. however.. in any case.. the ammeter should be registering a charge, if the batteries are that low.
Test the voltage at the battery... before the start and when running...
Soundguy
Thanks Guys ,Iwill get an ampmeter at work tommorow.Iwill check the caps today and all connections. /forums/images/graemlins/laugh.gif Thanks,Ricky
SPIKER,Ijust found small stickers on top of my battery caps that said,REMOVE. It is all charged up now and everything reads right. /forums/images/graemlins/laugh.gif Thanks a lot. Ricky
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A53472)
2014 Doyle Dry...
2020 Ford F-350 Pickup Truck, VIN # 1FTBF3A68LEC75327 (A51572)
2020 Ford F-350...
2007 International 7600 Tandem Truck, VIN # 1HSWYAHR37J478209 (A51572)
2007 International...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51406)
KNOW BEFORE YOU...
CATALOG IS A GUIDE ONLY!! (A50775)
CATALOG IS A GUIDE...
2018 HINO 268  NON CDL 26FT BOX TRUCK (A52576)
2018 HINO 268 NON...
