FarmPro 2420 Maximum Tilt
   / FarmPro 2420 Maximum Tilt #1
DavidBradley
Can anyone tell me what the maximum tilt ange for the FP2420 2 wheel drive with front and wheel weights is? Thanks in advance for your help.
Dave
   / FarmPro 2420 Maximum Tilt #2
Depends upon at which width you have the rear wheels installed. There are up to four widths between 900 and 1020 mm, depending upon the wheel/hub/spoke configuration. Obviously, the wider the rear track - the greater the safe angle of incline.
John's Tractor will give you an idea of what I'm talking about
//greg//
   / FarmPro 2420 Maximum Tilt #3
It also depends on what you mean by "MAX TILT"
as in SIDEWAYS, you can travers 20 degrees depending on wheel width and how SMOOTH it is as well as any impliments you have attached, the PUCKER factor can go UP very fast if you hit a small hole or slip a bit on the front wheels. Over 20 degrees it is anybodys bet. The Jinma (farmpro, nortrac ect) tractors set HIGHER with a lot of ground clearance for going over stumps and such, (remember these are used in rice paddies around the world so water depth can play a factor as well as going OVER the small dikes that hold the water in the fields. ) Higher means less sideways angle traversing but better at going over log/stupm type structure longways.
You can also set the front wheels to different widths too. the backs have 4 different postions I run mine so fronts wide and rears are not, that way rears follow front's rut/path.
I have a 284 Jinma: and with my FEL installed 100% of time, front wheels OUT to WIDE rears are at middle. I go to 15~20 (estimated degrees) with out having too much of a pucker factor but I have come near to getting her over. two times due to ground hog holes ond once due to a bank cave in on the creek. (so now I've practiced up and eliminated over 10 hoggs so far this year) the creek was when I first got property and was clearing over grown multifloral rose / wild rose.
anyhow if you read up on JohnS's web site first you will get LOTS of good info... read it links too if need be and the JINMA maintenance too, (farmpro's are re-badged JINMAS )
Mark M /forums/images/graemlins/cool.gif
   / FarmPro 2420 Maximum Tilt #4
I don't think there is any set angle for sideways topple over,,,to many things to consider,,,,its not that great though,,I've had one rear wheel get real light on the side of a hill,,,,best to go up and down,,,,takes a while to get the feel of it,,,after you have went over your ground a few times,safely,,,you can do it again safely,,untill then,you got to be extra carefull,and extra carefull on new ground... thingy
2016 Ford Escape SUV (A50324)
2016 Ford Escape...
New Swict 66" Skidloader Bucket (A50774)
New Swict 66"...
UNUSED FUTURE EQUIPMENT SEAT (A51244)
UNUSED FUTURE...
2005 Mack Vision Semi Truck (NOT RUNNING) (A50774)
2005 Mack Vision...
Wolverine Mini Skid Grapple Bucket (A50514)
Wolverine Mini...
2012 Ram 3500 Crew Cab S/A Mason Dump Truck (A50323)
2012 Ram 3500 Crew...
