Hi All,
I'm new here so treat me gently. Great looking forum.
I have a Farmliner 445DTC and due to a lapse in concentration I drove off with the hand brake/transmission brake engaged.
I believe that something has let go or dislodged in the gearbox for the front axle drive/transmission brake which has allowed the drive shaft to get pushed forward out of the gearbox by about 1 INCH/2 CM. The drive shaft exits a transfer case mounted under the main gearbox and is used to select drive to the front axle and also has the transmission brake.
So I now have a tractor in the middle of the paddock with all the gearbox trans/hydraulic fluid emptied on the ground (no hydraulics for the linkage or bucket) and would like to know if anyone has any experience or knowledge of fixing this displaced drive shaft problem and what I need to do to rectify/repair the problem.
Sorry I don't have any pics.
Any help or information appreciated. My other concern, looking at the bolt heads is that there is not enough room for a socket wrench or ring spanner, only an open ended spanner will fit I hope I don't round off the bolts!!
Alan
Alan
