Farmi alternative for BX
/ Farmi alternative for BX #1
bxowner
Vermont
John Deere 5055e
I would love to be able to afford a Farmi or Norse... but can't justify the price for (1) what I plan to use it for and (2) for the tractor I own (a BX1500)...
So, I've been thinking about how to fabricate an inexpensive, small alternative and wonder if anyone has suggestions.
If I were to take a worn out rear blade and remove the blade itself, leaving behind just the frame, I could weld on a flat plate of steel with a couple of chain hooks welded to it. Then I could put a hand winch (like a boat winch, but with steel cable) on top to pull whatever tree/logs up against the plate.
What I'm really interested in is any suggestions about the "base unit" to fabricate against. My thought of using a rear blade is just came to mind.
/ Farmi alternative for BX #2
I'd leave the blade as a foot to hold it and depending on what you are dragging out you might be able to set a couple of chains for towing more then one log at a time. To be able to find a small winch with a free wheeling spool mounting about thirty inches over the blade frame should work well.
Now I would change the handle to be able to use a battery power drill on the winch to power it! Take a couple of batteries charged up and you should be able to run it all day and not build up a sweat!
Woods 15ft. Batwing Mower (A65640)
Woods 15ft...
7x16 Enclosed Spray Foam Trailer (A65563)
7x16 Enclosed...
2017 Hyundai Trailer (A62613)
2017 Hyundai...
2017 Scag 72" Zero Turn Mower (A64194)
2017 Scag 72" Zero...
2019 KENWORTH T680 (A65643)
2019 KENWORTH T680...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A63689)
2023 Kubota U48-5...
