Farmall Super M
   / Farmall Super M #1
wynnsong
Greenville, SC
New Holland TN60A, Farmall Super M
I have a 1953 Farmall Super M. The clutch has a lot of slop so I took the clutch peddle off, cleaned it up and found a machined rectangular groove on the inside of the clutch pedal that slides on the clutch/brake shaft. At one time it had a grease fitting to supply grease to this groove-the fitting was knocked off-and it had a remnant of a thin piece of metal in the groove. Does anyone know what goes into this groove? Also the clutch is not worn, but the shaft is necked down. Do I have to replace the entire shaft, seals and the works? Thanks. Ed
2018 Chevrolet Colorado Pickup Truck, VIN # 1GCHSBEA6J1312961 (A51572)
2018 Chevrolet...
2005 International 7400 Chassis Truck, VIN # 1HTWGAAT75J048748 (A51572)
2005 International...
2009 IC Corporation PB105 Passenger Bus (A51692)
2009 IC...
2015 DODGE RAM...
2025 New/Unused 72in Skid Steer Brush Cutter (A51573)
2025 New/Unused...
2018 Skyjack SJIII4740 4x4 40ft Scissor Lift (A52377)
2018 Skyjack...
