Farmall Super A - grease gun coupler stuck on throw-out bearing zert
   / Farmall Super A - grease gun coupler stuck on throw-out bearing zert #1
CricketC
Burnips, MI
Farmall SuperA
So... yeah. I've got little hands, but there are limits. Anyone ever pull this particular stupid before? Any idea of an easy way to fix it? Coupler practically fell onto the fitting - not coming off for love nor money.
   / Farmall Super A - grease gun coupler stuck on throw-out bearing zert #2
You do know that the coupler will loosen if you screw/twist the tip parts? Hard to explain, but the tip is in two parts that turn against each other to loosen/tighten the fingers that grip the zerk fitting.
   / Farmall Super A - grease gun coupler stuck on throw-out bearing zert #3
If the fitting did not take grease the deadheaded pressure will cause a lockup. Can you tip the coupler back and forth sideways? - That will usually pop it off. Often pressure will subside if given a little time, making release easier.
   / Farmall Super A - grease gun coupler stuck on throw-out bearing zert #4
Throw a bucket of cold water on it.:)
   / Farmall Super A - grease gun coupler stuck on throw-out bearing zert #5
Put the zerk in a vice and clamp lightly, then using pliers on the grease nozzle, rotate the nozzle sideways so it lets go of the zerk.
JOHN DEERE 1700 LOT NUMBER 17 (A53084)
JOHN DEERE 1700...
Polaris Side by Side (A50324)
Polaris Side by...
CATERPILLAR V50B STRAIGHT MAST FORKLIFT (A51246)
CATERPILLAR V50B...
2025 New/Unused LandHonor 13,000lb Electric Winch (A51573)
2025 New/Unused...
2013 International WorkStar 7400 4x4 Altec DMA71 Insulated Digger Derrick Truck (A51692)
2013 International...
2012 Nissan Rogue (A50324)
2012 Nissan Rogue...
