Farmall M Hydraulic problems
   / Farmall M Hydraulic problems #1
Olds25
Farmall M
New to posting here. Not sure if I should post this in this forum or the hydraulic forum. Please let me know if it needs moved or would get better feedback there. I assume you should not double post on this site.
To give specifics:
Farmall M 1951
Live hydraulics with an IH pump
Westendorf Jiffy loader
Cross 2 spool valve. 30 gpm, open center, 4 way, 3 position, spring center, one float.
Tank has been boiled
fluid full
Installed pressure gauge on pressure side
I have been having problems with system since I bought (4 years) tractor, but it almost unusable now. I can look in tank and see the fluid moving around and when I pull a spool valve it stops. So I know system is circulating oil. Loader will not work. Seem to work marginally better with bucket empty. Pressure never goes above
150 psi, never lugs engine, 95% of the time it never moves no matter how long you hold valve. if you hold down valve loader goes down do to gravity, to go up it is a crap shoot. It will not lift bucket when it works past the hood of tractor.
What else can I check??
I say pump bad??
I know there are plenty of new pump dealers out there. But a new one is a lot of buck (700+) when the tractor is only worth $1500 at most. Is a used one getting me any further ahead. Buying a different tractor can be a crap shoot also. I already have more money into the tractor than what it is worth and I know what I have.
Problem is, the tractor is worth nothing to me if hydraulics will not work.
   / Farmall M Hydraulic problems #2
To give specifics:
Farmall M 1951
fluid full
I say pump bad??
You might try posting over on YTMAG, they have a bunch of guys there that specialize in old farmalls.
   / Farmall M Hydraulic problems #3
Is this the pump that drives off the timing gears..?? Or between the timing gears, and distributor..?? Not familiar with them, other than seeing them on a few M's. Just wondering if it could be something as simple as something stuck in the by-pass valve, or just a weak spring..??
1985 Corn Husker Hopper Trailer (A50514)
1985 Corn Husker...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2021 FREIGHTLINER...
2023 JOHN DEERE 135G EXCAVATOR (A51242)
2023 JOHN DEERE...
E-Z Trail 680 Adjustable Head Cart (A50514)
E-Z Trail 680...
2014 Ford F150 XL Pick Up (A47384)
2014 Ford F150 XL...
