Farmall H, need help getting it running
   / Farmall H, need help getting it running #1
CraigM
Golden, IL
B2150HSD, JD3020
Finally got around to pulling the old H out of the shed and into the shop to get it running, and I need some help from those who've gone there before.
When it runs, it runs ok, but I've heard others that sound much smoother. It's a bear to start. I've had it running and heated up, shut it off and immediatly tried to restart and it won't. Five minutes later it's hooked up to another tractor to tow start it and it goes off instantly. Other times, we have to drag it around for 50 feet before it lights. Liberal quantities of ether shot into the carb intake (air cleaner coupler hose disconnected) don't help.
The fuel system is cleaned out from the tank through the carb, new gaskets, needle and seat. Occasionally it will still flood just sitting there. Used to do that everytime, so we've made some progress.
Ignition is magneto. We have new cap, rotor and wires coming. The timing seems to be close, probably a little late..(after TDC). Makes an ok spark at the magneto wire, but at the plug it's not all that strong.
What spark plugs do I put in? I don't know if the ones in it are right or not. If there is a heat range, I'd go hot since it seems to burn a little oil.
I set up the carb by the manual...idle open one turn and then set main. It will idle very slowly and responds to sudden throttle opening ok, but when running at what sounds to be about PTO speed, I can open the main needle 4 turns and it doesn't make a difference. There is a pretty definite roughening if I close the main needle beond a point, but there doesn't seem to be any point it goes too rich. Is this normal? Where do I set it?
Found out by accident that the starter turns the correct direction no matter which way I hool up the battery (+ or - ground). Dealer swears it's a permanent magnet motor. This doesn't add up. What's going on?
Manual calls for distributor grease. Where do I find that?
Manual says that engine serial is on the side above the distributor. Is there another place that they put them? Dumb question I guess, but it will save me the trouble of cleaning all the gunk off the engine right now.
   / Farmall H, need help getting it running #2
I'm at work and can't even pretend I have answers to all your questions right now. I'd have to be home even to go see what plugs are in mine. (That covers me pretty well, eh?)
I'll just recommend this site: www.farmall-h.com
I think he covers most of that. Good luck, and keep us up on how it's going.
Wm
   / Farmall H, need help getting it running #3
Have you checked the compression? Probably need rings if it starts only when cold. MikeD74t
   / Farmall H, need help getting it running #4
Adjust the valves...very simple process..BobG in VA
Will: great link, thanks
Mike: I've never used a compression tester. I have one, it came with the tractor in a can of mostly junk parts. Found a link to detailed instructions on compression testing from Will's link so I just need to know what numbers I'm looking for.
Bob: I haven't messed with valves. I see the procedure in the manual and it looks pretty simple. Maybe I'll try it.
Meanwhile, we have timed the magneto and put new cap rotor and wires on it. Haven't gotten to new plugs yet, forgot them last week in town. Had to remove the whole magneto unit and slip the drive gears a few teeth to get it to fire on the timing marks. That improved the starting a lot, but it's still a little less than reliable. Have put half an hour or so on it and had to clean out the carb bowl again. I'll get an inline filter in town tomorrow.
There's still no good mixture adjustment. It will idle very slowly and take sudden application of the throttle, so it seems that the idle mix is ok, but I can open the main needle 4 turns without it roughening at full throttle. At that point the needle is getting pretty loose feeling and I quit. There is a fairly well defined roughening when closing the main needle. At best, it runs erratically, like it's about to run out of gas, but it keeps on running. There is no carb adjustment I can make to smooth it out. When it's running at a fast idle it seems like one cylinder is firing at half power half of the time. The impression is that I can hear the crack from each cylinder in the exhaust, and one randomly goes poof rather than crack. Same impression at full throttle, but can't hear the individual cylinders, just a blip in the engine sound. Maybe new plugs will fix that, or maybe a sticking valve?
Another quirk is that in the shed I can run it against the brake in 5th gear and it will lug down to almost stalled and come back instantly when I push the clutch in. If I take it on the road, or across the lawn it runs noticeably rougher than against the brake.
So I have a tractor that starts most of the time, hot or cold; runs rough when sitting still and rougher when moving, but it keeps on running.
Anyone have any thoughts?
   / Farmall H, need help getting it running #6
If you are spraying either into the air cleaner and it doesn't fire that you have no spark!
   / Farmall H, need help getting it running #7
im new to this i hope you all can help i just bought a 1948 farmall h thats already converted to 12 volt my question is can you still use the crank start on the tractor
   / Farmall H, need help getting it running #8
Sure can...Farmall engines will usually fire up on the 2nd crank if they are in decent tune...6 or 12 volt won't make a difference on a hand crank start... BobG in VA
2012 WABASH 53x102 DRY VAN (A53426)
2012 WABASH 53x102...
2001 Ford F150 (A50121)
2001 Ford F150...
2019 Freightliner M2 106 26FT Box Truck (A51692)
2019 Freightliner...
2016 Nissan Sentra Sedan (A51694)
2016 Nissan Sentra...
2007 IH 4300 Dump Truck (A47384)
2007 IH 4300 Dump...
2009 SolarTech Silent Messenger III Solar Message (A53117)
2009 SolarTech...
