Farmall Cub
   / Farmall Cub #1
North Georgia
Lula, Ga
Kubota9000 Farmall Cub
Recently bought a couple of restoreable Farmall Cubs and am having a problem getting one of them out of gear. Shifter appears to be out of gear but doesn't disengage. Any one have thought of how to get it out of gear?
   / Farmall Cub #2
Hi North:
Suggest you post this query to the 'vintage tractor' area of the tractor by net forum. Get there from the list of posts page, at the bottom right is a drop down area, scroll down and the vintage tractor forum is down some.
simonmeridew
   / Farmall Cub #3
That痴 a common problem with Farmal and a lot of other H pattern older shifters.
The fix is take the 4 bolts off that hold the shifter down to the gear box. Lift the shifter up with the plate, look into the top and you will see haw the sliders push the gearing your forks are worn a little and one side R-1 0r the other 2-3 has failed to move to the center neutral position. With your hand place both sliders into the center neutral position, replace the cover with the shifter in the neutral position and it should work fine until someone once again tries a speed shift, usually between R and 2, If it continues to happen you can either replace the shifter forks OR just build up the dimples at the fork tips with a little brazing rod. KennyV
Fcubs are a fun little tractor, I have one..
2022 ELITE 102" X 40' GOOSENECK TRAILER (A50459)
2022 ELITE 102" X...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
2016 POLARIS RAZOR XP1000 (A51222)
2016 POLARIS RAZOR...
2007 CATERPILLAR 930G WHEEL LOADER (A51242)
2007 CATERPILLAR...
2021 CATERPILLAR 317 EXCAVATOR (A51242)
2021 CATERPILLAR...
Ingersoll Rand 185 Towable Diesel Air Compressor (A49461)
Ingersoll Rand 185...
