Farmall cub hydraulic leak
   / Farmall cub hydraulic leak #1
North Georgia
Lula, Ga
Kubota9000 Farmall Cub
Have a 53 Farmall Cub and the lift reservoir has a leak. Does this take regular hydraulic fluid? Thanks
   / Farmall cub hydraulic leak #2
Reg hyd oil is all I've put in mine for years and never had any problems.
   / Farmall cub hydraulic leak #3
Yes Reg Hyd Oil is called for. Don't put hy-tran in it.
Is the leak in the reservoir or the cylinder?... well my Cub leaks both places, but not enough yet to break her up.
Leak appears to be in bottom of reservoir. It is not really bad yet. Put some hydraulic oif in reservoir to bring up to full mark. This seems to have solved my problem. I did notice that Farmall Cub. com has a complete rebuild kit for the system for about $40. Will consider that if needed..
Thanks for your input.
8ft x 6ft Container with Side Door (A51573)
8ft x 6ft...
John Deere 2020A Progator (RUNS) (A50774)
John Deere 2020A...
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
2011 Manac 36245B30 45FT T/A Walking Floor Trailer (A50323)
2011 Manac...
2004 Ford F-250 Pickup Truck (A50323)
2004 Ford F-250...
