i have a 49 farmall cub. you can take a plug out, check the fire and if you have fire it will start. it runs better than a cadillac. may run 20 seconds or 2 minutes and 20 seconds. when it quits, you have no fire. have replaced ignition switch, coil, points and condenser, coil wire, and insulator where wire goes in dist for points.have also inspected wiring. you can go anytime and check fire, if it is there it runs for short peroid of time... when you have no fire, i am getting power to the coil. tractor was rebuilt a few years ago and has not been ran many hours since. at that time dist cap, rotary button, etc were all replaced... any ideas would be appreciated.. have about lost my religion over this. am convinced it is something simple, but i can not see the forest for the trees!
