Farmall Cub clutch problem
   / Farmall Cub clutch problem #1
Killowatt
Western NY
Kioti CK20HST
I have a '53 Farmall Cub and it's a great little workhorse, but it's clutch petal shaft sticks so badly that I have to manually pull it up by hand! It's also begun to affect the left brake.
I've lubed the snot out of it on both sides of the main body to no avail! The clutch(and brake) work OK, but how do I free up this stuck shaft? I've heated it with a torch, tried to remove it, and used plenty of lube!
Is there something inside that could be causing the sticking? The release bearing and linkeage are free. I don't want to tear the tractor in two if I don't have to!
Help! Anyone?
Gratefully,
Killowatt
2013 Ver-Mac Solar S/A Towable Trailer Message Board (A49461)
2013 Ver-Mac Solar...
1274 (A50490)
1274 (A50490)
2015 Dodge 5500 4X4 Bucket Truck (A51039)
2015 Dodge 5500...
NEW 2022 Load Trail CH 83IN x 18FT Equipment Trailer (A51039)
NEW 2022 Load...
2014 MACK GU813 GRANITE ROLL OFF TRUCK (A50854)
2014 MACK GU813...
EVERYTHING SOLD AS-IS WHERE IS!! (A50775)
EVERYTHING SOLD...
