Farmall Cub Battery Box Dimensions
   / Farmall Cub Battery Box Dimensions #1
Deano
Veteran Member
Southern Maryland
Kubota BX24
Does anyone know the dimensions of a Farmall Cub tractor??
Thanks,
Deano
   / Farmall Cub Battery Box Dimensions #2
Mine was just slightly larger than the 12-volt that fit in it. It had a hard cover, with the wires coming into it on the top sides.
A very snug fit. I guess you can start with that.
   / Farmall Cub Battery Box Dimensions #4
I never liked the battery in a box on the operator's platform. I converted my cub to 12 volts so that I can run a standard sprayer pump. I use a GM-style battery with side posts, supported below the operator platform, using a couple 3/8" threaded rods up thru the platform and a plate across the bottom of the battery. This leaves more room up top for added operator comfort and is a big improvement over the factory setup in that regard.
2011 GR TRAILER GOOSENECK (A50854)
2011 GR TRAILER...
2022 Mack MD Rollback Truck (A50323)
2022 Mack MD...
2016 Case CX55B Mini Excavator (A49461)
2016 Case CX55B...
2008 UTILITY REEFER TRAILER (A51222)
2008 UTILITY...
Landoll (A50657)
Landoll (A50657)
2013 Ver-Mac Solar S/A Towable Trailer Message Board (A49461)
2013 Ver-Mac Solar...
