Mid-Mount Mower Farmall B needs belly mower lift levers, etc...
   / Farmall B needs belly mower lift levers, etc... #1
pusto3
Moulton, Tx
NH 3930 IH B
My Farmall B, which I have used only for pulling a hay rake, needs to have the equipment that I would need to attach a mid-mount finish mower. The tractor is stripped down, and has no levers, brackets, or whatever. Maybe someone has some ideas where to acquire such things, or alternatively, how to attach a belly mower without any of that. Thanks.
   / Farmall B needs belly mower lift levers, etc... #2
Do you already have the belly mower..?? If you were planning to get new, Woods used to have mowers for the classic models, and the lift levers, and attaching pieces. It will NOT be cheap..!!
30- some years ago, I fixed up an A to sell with a belly mower. Bought the mower used, in good condition. The mounting kit, belt, and lift lever was right at $350.00 then. More than I paid for the mower, which was in great condition.
Just make sure you get a mower suited to your tractor. They make them in CW rotation, and CCW rotation. Some tractors belt pulley such as your B is mounted on the right. A buddy of mine's A-C CA is mounted on the left. Both turn CCW on the belt pulley, but being on different sides makes a belt turn the opposite direction, to an implement. Not so bad on the old flat belts, where you just flip them half over to correct direction.
   / Farmall B needs belly mower lift levers, etc... #3
Look at pictures of that Allis he mentioned, as they are simple and that design might be easy to coppy,
David from jax
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
2014 Nissan Pathfinder SUV (A51694)
2014 Nissan...
2015 Volkswagen Passat Sedan (A51694)
2015 Volkswagen...
2020 KUBOTA RTV...
11 10 FOOT BY 5 FOOT LIVESTOCK PANELS (A53843)
11 10 FOOT BY 5...
2012 VOLVO BL70B BACKHOE LOADER (A51406)
2012 VOLVO BL70B...
