Farmall A w/ vacuum lift
   / Farmall A w/ vacuum lift #1
Ledgemere Farm
Veteran Member
Limerick, Maine
A bunch
Anybody know how to lift the sicklebar on a Farmall A w/ a vacuum lift? The mower mounts on the back. There is a small lever, that when pulled forward, will lift the mower. The lever is about 8 inches long with a hole in it. I have seen these on Super A's, but they connect to the rockshaft. This tractor has no rockshafts. Thanks. /forums/images/graemlins/confused.gif
   / Farmall A w/ vacuum lift #2
You might want to try over at yesterdaystractors.com. They have a great Farmall section on their board.
   / Farmall A w/ vacuum lift #3
Sure do. I had a 1941 Farmall A that I sold to a guy who had it restored. He put hydraulics on it, however.
I stlll have the vacuum cylinder, the single bottom plow and the rockshaft in the barn.
The way it works is:
When you pull on the lever, there is a linkage that connects to a device that mounts on the top of the exhaust/intake manifold. Essentially, it is a valve that has a metal flap in it. When you push the lever forward, it closes the flap and sends the exhaust gas into the hose that connects to the cylinder. That causes the cylinder to retract, lifting the implement by means of the rockshaft. When you pull the lever, it opens the flap allowing the gas to escape, lowering the implement. The cylinder is porcelain lined and has a large leather seal inside it. When the lever is in the neutral position, a check valve keeps the gas in the cylinder, "floating" the implement. The hose on my Farmall was nothing more than a black rubber hose with fittings on the ends that were just like the fittings on your garden hose. It worked pretty good. In fact, the single bottom plow is pretty heavy and it lifted it no problem.
Thanks. I have another question: How do you hook the lift up to the mower?
   / Farmall A w/ vacuum lift #5
IHCRules:
Ooooohhh!, thats a hard question to answer. I had an L-59 woods belly mower on my "A" that had a ratcheting hand lever that mounted right in front of your face. I never hooked it up to the rockshaft, but I suppose you could with a little country ingenuity.
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2015 International DuraStar 4300 26ft. Box Truck (A51692)
2015 International...
2014 MACK GU713 DAYCAB (A53843)
2014 MACK GU713...
2024 Deere 317G (A50123)
2024 Deere 317G...
