Farmall 85 or Kubota M8540
   / Farmall 85 or Kubota M8540 #1
Kubota Rox
Knoxville, MD
Kubota 4630
I don't know much about the new Farmall brand. What is the word on comparisons?
   / Farmall 85 or Kubota M8540 #2
I'm not familiar with the farmall 85 but if you look on the Kubota site they usually has comparisons against other comparable brands, it might give you some idea.
   / Farmall 85 or Kubota M8540 #3
Ok looking at the specs on the two respective sites they look very similar in specs.
Kubota 6680 lbs. farmall 6280 lbs.
3 pt lift. Kubota 7275 (optional). Farmall 4630 ( no optional increase)
Hyd flow. Kubota 17.0 gpm. Farmall 16.9 gpm
Both have one rear remote standard
Both have an optional 12x12 hydraulic shuttle transmission
Kubota 230 cu in Vs farmall 195 cu in. Not sure this is an advantage one way or another.
Wheelbase is within an inch between them.
Standard tire size is the same.
Take the time to go operate both of them as "on paper" they look very similar.
2007 GMC C5500 Service Truck, VIN # 1GDE5C1967F422895 (A51572)
2007 GMC C5500...
PALLET OF ARMSTRONG CEILING INSULATION (A51248)
PALLET OF...
26ft x 24ft Metal Building (A51573)
26ft x 24ft Metal...
2007 Ford Ranger Pickup Truck (A51692)
2007 Ford Ranger...
UNUSED RAYTREE RMAU2 AUGER (A51248)
UNUSED RAYTREE...
