Farmall 75A vs 75C
   / Farmall 75A vs 75C #1
Soggy Bottom Outdoors
Brandenburg ky
2013 john deere 5075E and others
Several thousand in price separate the two models but: They have the same engine, are within 100lbs of the same weight, have the same tires, are within 500lbs of the same 3pth lift capacity, are within a couple gallons of hydraulic pump capacity. The 75C does have more transmission choices including hydraulic and mechanic shuttle and a much, much nicer operators platform. (I test drove both) But such a wide price range? I'm I missing something? Thoughts anyone.
   / Farmall 75A vs 75C #2
From what I understand, the A series should have a heavier frame and capacity than the C series. However, the C series will have more options for fancier transmissions and push button pto engagement. The A series is a more basic workhorse tractor. You should carefully review the specs from the Case website.
2017 John Deere 8345R MFWD Tractor (A53342)
2017 John Deere...
2014 Doosan DA30 (A53472)
2014 Doosan DA30...
(1) UNUSED 7000# DROP AXLES W/ BRAKES (A51247)
(1) UNUSED 7000#...
UNUSED AGT 3000 PSI HOT WATER PRESSURE (A51248)
UNUSED AGT 3000...
2018 Bobcat T595 (A47384)
2018 Bobcat T595...
Kubota LA853 Loader Arm (A51691)
Kubota LA853...
