Farmall 560 Rear Remote Question
   / Farmall 560 Rear Remote Question #1
mbeckett
New Douglas, IL
Ford 641 Workmaster
I am looking at a Farmall 560 with a quick attach loader. The Loader is controlled with the two levers to the right of the steering column. Do these levers also control the rear remotes, If so would I have to unhook the loader every time I want to use an implement with the rear remotes, or is there a way to lock out the loader in an up position so you don't have to unhook it. Or is there a lever somewhere else that controls the rear remotes that I overlooked?
Thanks in advance.
   / Farmall 560 Rear Remote Question #2
I've never had to do what you are asking but you could put valves on a set of lines.
SHOPBUILT 40FT FLARE STACK (A52472)
SHOPBUILT 40FT...
2022 LMC H40024 LOT NUMBER 206 (A53084)
2022 LMC H40024...
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
2020 Chevrolet Silverado 3500 HD 4X4 Service Truck (A52377)
2020 Chevrolet...
E-Z-Go Freedom TXT Electric Golf Cart (A51694)
E-Z-Go Freedom TXT...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
