Farmall 40 or 45
   / Farmall 40 or 45 #1
KSSS
Idaho
CASE 465, CASE 440, TK TB153FR, CASE 9020B
Hello all,
I am considering buying a compact tractor to run a laser grader (three point box blade) attachment. The attachment is 7' wide. The application is in concrete preparation so the material is typically 3/4 crushed roadbase. I want a cab so that I can mount Laser equipment inside the cab and not have to unhook it every night. I currently have this attachment on a CASE 440 skid steer and it works fine but it ties up a skid steer and due to mounting of the laser equipment I cant put my door back on. I am considering either of these two models due to HST tranny and cab options. Does anyone see any issues with pulling a 7' foot box blade in loose 3/4 type material? I have never run a compact tractor before (I grew up red tractors 1066-3788) but no experience in anything like this. Is there any advantage in the 45 over the 40? I built both on the CASEIH website and it looks like the 45 is only a couple K over the 40. I am not interested in looking at any other color. Its Red or not at all.
   / Farmall 40 or 45 #2
I pull a 6' box blade with my d40 with absolutely no problem, think loose gravel with a 7' will work fine. I would go with th dx45 but understand there is no difference in pop-off valve setting between dx40 and dx45. I am with you on "Red or Nothing" Somehow the blue don't get it for me.
   / Farmall 40 or 45 #3
The 40 will do what you want no problem the only time you may want the extra hp would be for pto work.
2021 ALLIANCE NORTH AMERICA, INC AIRMAN SDG45 GENERATOR (A50854)
2021 ALLIANCE...
HOPKINS 40 TRI-AXLE DATA VAN TRAILER (A50854)
HOPKINS 40...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
Online Buyers Premium (A47384)
Online Buyers...
2000 Safari C-Series 425 40ft Panther Motorhome (A49461)
2000 Safari...
AGT Agrotk 680 Drop Hammer Attachment (A47384)
AGT Agrotk 680...
