farmall 340 hydraulic wtf?
   / farmall 340 hydraulic wtf? #1
superCslim
Nowata Oklahoma
farmall super c, farmall 340
I just picked up a 1958 farmall 340 it's a good running tractor but the hydraulics do not work. I rebuilt the pump thinking that would be it but still nothing. The pump is working. I have pressure all the way back to the fast hitch and it's valve is not stuck, it moves freely. But the other two valves are very much stuck.
The pump does not bog down when I move the lever. It seems like there is something not letting the fluid build enough pressure in any position the lever is in.
What should I be looking for?
   / farmall 340 hydraulic wtf? #2
Did you change the filter?
Yes. New filter new oil.
   / farmall 340 hydraulic wtf? #4
It has been about 40 years since I worked on a 340.
Do a google search on Farmall 340 hydraulic problem.
   / farmall 340 hydraulic wtf? #5
Sounds like you have a pressure relief valve,, or flow control valve stuck, or hanging open in the system.
Yeah that's what I'm thinking But where would it be at specific to that model? I don't know a lot about hydraulics. If I have to tare into the valve stack I was kinda hoping to go right to it. Also don't want to spend the annual budget in one spot.
   / farmall 340 hydraulic wtf? #7
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
Set of Ag R4 Wheels and Tires (A52748)
Set of Ag R4...
2012 Chevrolet Traverse LTZ SUV (A50324)
2012 Chevrolet...
1996 JCB 6K42 Telehandler (A50322)
1996 JCB 6K42...
377811 (A48836)
377811 (A48836)
2015 Ram 5500 Versalift SST-40NE 40ft Sign Bucket Truck (A50323)
2015 Ram 5500...
