8ntractorjdx
Hi all I am in a little trouble here as the snow is piling up.
I have a farmall 200 basically a super c with a tube style loader. the hydraulics have been marginal since buying the tractor but they did work all summer I moved approx 100 tons of gravel over the summer. but now they will not work. the last time I plowed they were slower than normal and I tightened all of the fittings as it looked like the oil had air bubbles . today the hydraulics will not work at all.
The motor rpm will increase speed when the touch control levers are pulled back or the fast hitch lever is moved into position.
there does not appear to be extra oil in the crankcase.
there is a two way valve that allows the oil to go to the fast hitch lever in one position and the loader valve in the other and it seems like over the years sometimes have to move that valve back and forth to get the loader to work.
I have done the following to the hydraulics this year but the hydraulics worked after doing these things.
== replaced the 1 gallon tank with a five gallon tank as the one gallon tank overflowed often the 5 gallon tank does not.
== replaced the inexpensive hyd oil with IH recommended low foaming oil it has been drained and refilled twice.
== replaced the strainer with a new one (most expensive oil filter I ever bought).
The tractor has sat for the last couple of months without running. I did plow snow last week with it but the hydraulics were not functioning correctly then either.
I have very little hydraulic knowledge.
I would appreciate any troubleshooting tips
