Tractor Supply shows they carry them. They may not be in stock, but can order them. The I&T manuals have a lot to be desired, but get you through most repairs, and have most specifications as far as torque setting, tune-up specs etc. Look to run $32.99 there. The manual you would need is the I&T IH-201.
The IH Blue Ribbon manuals are best by far, but are segment specific, such as wiring, transmission, engine, etc, etc, by separate manual. The full set will nearly, if not completely fill a loose leaf binder.
There are some OEM Blue Ribbon Op. manuals on Ebay right now, for less than $20.
If you need to look up parts, click on this link:
Official Case IH Online Parts Store and Case IH Catalog for Best Parts Search and Best Parts Look Up. Case IH Parts for Case IH Tractors, Case IH Combines, Case IH Tractors, Case IH Manuals, Case IH Parts It's to the Case/IH online parts store. I've already drilled down through the menu,and got you to the pages for the 140. Select a segment of your tractor, and click on it, and an exploded view of it will appear, along with the part number, and description to the right.
Or, you can go to Messicks:
Home | Messick's Same exploded views, but they show parts prices. Handy if your shopping for aftermarket parts to compare, or looking for used parts. Copy and paste the part numbers to Google, NAPA, to compare prices.
