farm wagon hub replacement
/ farm wagon hub replacement #1
rasorbackq
Platinum Member
Springfield Nova Scotia Canada
Branson 4720
Bought an old wagon and was missing a hub and all the goodies inside. Now I do have a complete other side to match up the inside parts.
I have found all the bearings part #s but not a # for the hub. The spindle is a 2 step spindle with one bearing a 1" and the larger step in the spindle is a 1.98" (from the bearing info). Both are tapered.
Its a 5 bolt hub and is 4 1/2 spacing measured from outside one hole to the center 2 holes away. Where do I look for what I need in Canada. Princess Auto does sell the bearings but not sure about a complete hub.
/ farm wagon hub replacement #2
See if you can find a spindle that matches yours, then a hub to fit. With the make and model known, check with a trailer supply in Canada.
spindle - etrailer.com Search
Bruce
