farm pro wont start
/ farm pro wont start #1
ROBERT CORDER
FARMPRO 2420 TY290 ENGINE
just bought tractor 2420 lost power after driving .5 mile what should cylinder pressure be checked all fuel lines pop tested injrctors they passed wont start with out starting fluid stays running with fluid sprayed into air itake what should i do next:mad:
/ farm pro wont start #2
Post this on the chinese tractor board on these forums. Scroll down and you will find it. Welcome aboard..
/ farm pro wont start #3
Like said before check the Chinese section on this site. To get you started though it sounds like a fuel delivery problem. Many have had this issue.
Drain fuel tank and remove the hose between the injector pump and the fuel bowl. There is a screen in there. Also remove the fuel shut off and fuel bowl, there is a screen where the shut off is threaded into the tank. 9 times out of 10 its this. Clean the tank and put it all back together, use the primer pump on the injector pump to get the fuel up to the filter, and crank. If it will not start take each injector hard line loose at the injector while cranking to bleed the air out.
Chris
/ farm pro wont start #4
The first thing I would do is STOP using the starting fluid, then go through the fuel lines to clear the obstruction. If you do compression test, squirt some oil in each cylinder, they will be dry after using starting fluid and affect the readings.
1997 Freightliner FL70 Rollback Truck (A63116)
1997 Freightliner...
LandHonor 15'x7'x7' Greenhouse (A62183)
LandHonor...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
Chevrolet Tailgate (A62183)
Chevrolet Tailgate...
2005 Chevrolet 2500HD (A62180)
2005 Chevrolet...
2017 International Prostar 122 Day Cab (A62613)
2017 International...
