farm pro lube specs
   / farm pro lube specs #1
frigman
oxford ohio
farm pro 2425
I just bought a farm pro 2425---used---37 hours on it. I live in Ohio. what oils would you recomend for the trans,engine and hydralics. also what grease should I put in the zirk fittings.also---is there a drain for the front axle assy? I,m totally new at this--so forgive me for all the questions
   / farm pro lube specs #2
I use
Shell Rotella T 15W40 (engine)
Shell Spirax HD 80W90 (both diffs/tranny)
NAPA AW46 (hydraulics/steering)
ISO100 compressor oil (injection pump)
and Slick50 "One Grease" because of it's universal compatibility
There are actually three drains up front; the main one is in the center of the axle housing, the other two are on the underside of each drive hub. It comes out slow, so it's best to drain while what's in there is still warm.
If you can't find out from the previous owner, I think you should assume that it's never been flushed either. It's very important to get all the manufacturing and break-in residue out of these things before it's given a chance to do any harm. If you're unfamiliar with flushing, it's a widely discussed topic here. The search engine will turn up lotsa info.
//greg//
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
2003 Chevrolet Silverado 2500HD Ambulance (A51692)
2003 Chevrolet...
1996 Timpte 46ft Hopper (A53473)
1996 Timpte 46ft...
2022 Adams CLC-1013 Conveyor - New (A53473)
2022 Adams...
2015 Ford F-450 Knapheide Service Truck (A51692)
2015 Ford F-450...
2019 Komatsu D51PXi-24 Crawler Tractor Dozer (A51691)
2019 Komatsu...
