Farm pro/Jimna oil leak
   / Farm pro/Jimna oil leak #1
Minnow Creek Farm
Farm pro
I have a farm pro 2425 that has an oil leak from loose bolts securing the flywheel cover to the engine. I will be replacing the bolts with new metric 8.2 grade bolts as well as the real engine seal.
I feel I should replace the gasket between the engine and the flywheel cover but uncertain if completely removing flywheel cover has any gotchas or parts that might drop out of slots or jetways.
Suggestions?
I could just replace hardware, oil seal and check torque specs but in this deep would make replacing the gasket easier now rather than later.
   / Farm pro/Jimna oil leak #2
Get your self a parts list so you can see what
goes where and if you need any part you will
have the part number.
willy
HAMM 3205 SMOOTH DRUM ROLLER (A51242)
HAMM 3205 SMOOTH...
SKID STEER FORKS (A53843)
SKID STEER FORKS...
2019 JOHN DEERE 310SL HL BACKHOE (A51406)
2019 JOHN DEERE...
2011 INTERNATIONAL DURASTAR 4300 M7 BUCKET TRUCK (A51406)
2011 INTERNATIONAL...
JOHN DEERE 1705/6700 (A53084)
JOHN DEERE...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A54811)
2019 Caterpillar...
