Hey guys I have a 2006 Farm Pro 2430 with the TY395i engine. It overheats when I use the bush hog or finish mower in heavy grass.
1. I removed the thermostat first.
2. Replaced the radiator cap.
2. I then replaced the factory temp gauge/sending unit with one that reads Fahrenheit. Both show about the same temps, 180 degrees within about 15 minutes of heavy mowing. If I keep mowing the temp will continue to rise, I haven't let it get past 210 degrees.
It will push about a half gallon of coolant from the radiator overflow when the temp rises.
Doesn't seem to be building excessive water pressure like a blown head gasket would do.
If I am just using the front end loader or other light work the temp will stay in the 160 degree range, again this is with thermostat removed.
The passages in the radiator look clean. Engine start easily and sounds good with no excessive smoking from the exhaust.
I have noticed that at idle or when revving the engine, there is no noticeable water flow in the top of the radiator.
Could I have a defective water pump? Is this a common failure on these engines? At $170 for the water pump I would hate to replace and not solve the problem.
Thanks in advance for any suggestions.
Randall
Randall
