farmerben8
So I just split my tractor today to address the leaking gasket between the sump and flywheel housing. It went pretty well, minus a few minor hurdles. Ive got it stripped down to the gasket, there was basically nothing left of it! A few of the larger bolts holding the flywheel housing to the engine block were pretty loose, one I could remove by hand, three others barely needed any torque to move! I'm hoping to get it cleaned up, install a new gasket and get it back together tomorrow. A couple questions as I tackle this re-assembly, mostly regarding proper fluids to replace and how to go about that:
- what type of fluid do I use for the power steering? It was a creamy filthy fluid that came out when I cracked the banjo fitting at the pump, cant tell what is supposed to be in there!
- I mistakenly removed the back square cover off the transfer case for the 4wd trying to figure out how to remove the driveshaft. It leaked about a quart of fluid, is this the same used in the transmission? Where do I fill this transfer case, there was a drain plug at the bottom but i cant find a fill plug...
- When I cracked the hydraulic lines there was little fluid that drained (1/2 gallon?!?), and i noticed the fluid level was off the stick when I parked it to start the dis-assembly, it seems like the major leak is from the pto output shaft. Is there a oil ring or gasket behind that plate which needs replacing?
- What torque should the flywheel housing bolts be set to? there was two different sizes, six 10mm and another six were 16mm I believe.
Thanks yall, Im excited to have this thing up and running soon. I just bought a 4' JD tiller and spring is breaking fast!
- Ben
- Ben
