Farm pro 2425 levers
   / Farm pro 2425 levers #1
rkadish
farm pro 2425
On the right side there are 4 levers
PTO eng/dis
3PT raise/lower
PTO speed
And another long through engage/disengage right beside the 3PT R/L. What is that one for? Mine seems to move back and forth with no resistance or engagement. Also I cannot engage/disengage my PTO with clutch in. I have to turn the tractor off to engage the PTO.
   / Farm pro 2425 levers #2
The 4th lever is to engage the lock on the rear axle. To be used when one wheel is spinning and the other it not. Should be disengaged when turning.
Your clutch needs adjustment. if the PTO won't engage or grinds when trying to engage.
Thank You.
Should the rear axle lock move so freely?
Do you have a tutorial on how to adjust the PTO and Clutch? I found one video but is not very informative.
   / Farm pro 2425 levers #4
Go to my web site here: Harnerfarm Jinma 284
The first document has a pretty good drawing of the clutch mechanism on page 29. It also walks you through the adjustment procedure. Feel free to download and keep any of the documents from my site, they are not mine, I'm just sharing them freely.
The second document has the same information starting on page 22
Also see this thread: jinma 254 pto clutch adjustment - reading the manual
And this one: Jinma 284 Clutch Problems
Here is one about the diff lock handle: Jinma 284 Rear Differential Lock Adjustment
The search function on this site is really pretty good, I am sure you can find more threads, this was just a first pass based on my memories.
NEW Fork Extensions (A53002)
NEW Fork...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
1/2 '' Wolverine Universal Quick Attach Mount Plate (A51573)
1/2 '' Wolverine...
NEW Wolverine Skid Steer Pallet Forks Hydro Adjustable (A53002)
NEW Wolverine Skid...
2025 New/Unused 72in Skid Steer Brush Cutter (A51573)
2025 New/Unused...
2013 F-550 Bucket Truck (A53472)
2013 F-550 Bucket...
