Farm Pro 2425 fluid leaks?
   / Farm Pro 2425 fluid leaks? #1
Garycw
Platinum Member
Oh-Ky-Fla
JD 1025R w/ fel, Farm Pro 2425, ford 841 & 851
While using the 2425 today moving dirt I had several leaks develop. I found a hose fitting that needed tightened near under seat, bottom of steering looks like bolts need tightened and two on top of rear axles.
I've got the hose leak stopped, still looking for wrench size to fit steering bolts. The two small threaded holes on top of axels near lift arms was gurgling fluid out. What are these holes for?? I put two 7/16 bolts in them to plug. For now. Also does anyone have a good like for maintence, fluid recomendations, fill/ drain locations. I had a good one from here, but can't find now.
2014 MACK GU713 WATER TRUCK (A51243)
2014 MACK GU713...
2024 John Deere 872GP Articulated Motor Grader (A49461)
2024 John Deere...
2016 Ford Explorer...
2018 CATERPILLAR 308E2 CR EXCAVATOR (A50458)
2018 CATERPILLAR...
2015 CATERPILLAR 259D SKID STEER (A51242)
2015 CATERPILLAR...
2023 TAKEUCHI TL10V2 SKID STEER (A51242)
2023 TAKEUCHI...
