Farm Pro 2420
   / Farm Pro 2420 #1
Jefferson_D
Is this 2 wheel drive tractor strong enough to be equipped with
a 6 foot rear finish mower?
   / Farm Pro 2420 #2
In flatland, I'd say no problem. If you're mowing hilly country, you might want a test drive before you sign the check
//greg//
   / Farm Pro 2420 #3
actually with a 20 hp tractor I wouls stay at the 5' finish mower. and a 4 ' rotary mower. weight is probalby OK for a 6' but lifting it and running it in anything that is very heavy may be too much on the tractor. with the 5' you will need more passes but you will be less punishment on the tracor. not to mention how much the 6' weighs? maybe too much for the 3pt even with weightson front it may not raise it fully...
Mark M
   / Farm Pro 2420 #4
</font><font color="blue" class="small">( actually with a 20 hp tractor I wouls stay at the 5' finish mower. )</font>
That might be just a bit conservative Mark. I ran a five footer under a JD430 (22hp) and it had LOADS of power in reserve. RuralKing sells the JM200 with a 5 foot MMM. Since that's intended to be adequate for ALL finish mowing applications, I think a 20hp Jinma would handle a six foot RFM just fine - for general purpose finish mowing on flatland. Like I said, factor in hillside - and the equation changes.
//greg//
   / Farm Pro 2420 #5
I would recommend a 5' finish mower! You will still have lot's of manuverability and less weight.
   / Farm Pro 2420 #6
</font><font color="blue" class="small">( I would recommend a 5' finish mower! You will still have lot's of manuverability and less weight. )</font>
The question was Is this 2 wheel drive tractor strong enough to be equipped with a 6 foot rear finish mower? . The answer is yes. Weight may be an issue in transport, but again - more of a hillside issue.
Having said that, I agree on the maneuverability point. A six footer might be too wide for mowing in restricted areas. After all, the 2420 ain't but what - four foot wide or so? That leaves better than a foot of RFM sticking out either side.
Like I said, it all depends what and where you're going to mow with it. Large open flat acreages can be mowed 20% faster with a six footer. But hillside mowing - especially if it requires a lot of maneuvering, or travel with the mower lifted - makes a five footer sound more sensible.
//greg//
   / Farm Pro 2420 #7
Greg:
while I hate to dissagree with people I have to here, I have a JM284 with a 5' RFM: it pulls it fine, and could handle a 6' but in high grass it will bog it down too much and I have to drop to LH3. mowing speed is better at HH1
I'm sure the MMM 5' would even push the JM200 tractor. useable yes, more steady on hills with MMM yes, will it live longer? probalby much more stress on the 200 series for sure. the 250 would be fine with the 5' and maybe even the 6' on level ground IF the grass is cut weekly so it has less than 4' height. mine soemtimes gets higher as I have 4~6 acres which I mow...
Mark M
/forums/images/graemlins/ooo.gif
2008 Ford Escape Hybrid SUV (A51694)
2008 Ford Escape...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
INSPECTION (A51573)
INSPECTION (A51573)
2022 Polaris Ranger 4x4 Utility Cart (A51691)
2022 Polaris...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
