Farm Pro 2420 2WD
   / Farm Pro 2420 2WD #1
labowners
I have a front end loader on my tractor and the brush hog works just fine when going up then lowering. My front end will not lower or actually do anything. I have added hydraulic fluid today and it lasted maybe 5 minutes then just quit doing anything in. I'm not sure if it got air in the lines or anything.
anyone have any suggestions? It has a TY290 engine. I believe it is a 2003. I bought it used.:confused:
   / Farm Pro 2420 2WD #2
It would help to know how the loader is plumbed into the tractor hydraulic circuit. I take it the loader arms don't go up and down. How about the bucket curl? Or doesn't it work at all. And does the loader have two control levers, or just one joystick type controller?
//greg//
   / Farm Pro 2420 2WD #3
Has the FEL ever worked?
Also clarify what you mean by "I have added hydraulic fluid today and it lasted maybe 5 minutes then just quit doing anything in."
RonJ
   / Farm Pro 2420 2WD #4
Need more information,the TY290 uses 1-hydraulic pump so if the 3-point is working OK,and the loader is not working I would look at the loader valve,when you said it worked for 5-mint,what worked ?Also check your engine oil to see if the pump seal has blown filling up the engine block with hydraulic oil,the Farmpro 2420 is the same as a Jinma 200 series
Tommy
Affordable Tractor Sales
" Your Jinma parts Superstore "
Home of compact Jinma, Foton, and Koyker Tractors and Parts, Wood Chippers, Backhoes - Affordable Tractor Sales Company
NEW Ripper Shank (A53002)
NEW Ripper Shank...
Kawasaki NR (A50324)
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
Adams 5 ton Fertilizer Buggy / Wagon (A53472)
Adams 5 ton...
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
