Tractor Sizing fan belt size?
   / fan belt size? #1
sirgknight
South Georgia
Early model YM1700
need to know the fan belt size for my older model YM1700. Can't tell from the old one as it shredded into several pieces when it flew off the tractor. Thanks.
   / fan belt size?
I thought someone might be lurking around and know about the fan belt. I took my tape measure and folded it around the water pump, camshaft and altenator pulleys. It measured from 37" to 39" (shortest to longest adjustment of altenator). I purchased a belt from O'Reilly's that was 37.5" long. Purfect fit!!! $4.
   / fan belt size? #3
Do you have the 5 numbers from the new belt? I think the first two give the width and the next three give the length. What orielly part number was it? I need one also.
thanks,
Bill
2021 POLARIS XP1000 RANGER (A51222)
2021 POLARIS...
1981 Case 245 2wd tractor with Rotary cutter (A51039)
1981 Case 245 2wd...
2018 Toro Sand Pro Bunker Rake with Edger Broom (A49461)
2018 Toro Sand Pro...
2004 FREIGHTLINER COLUMBIA 112 MID-ROOF SLEEPER (A50854)
2004 FREIGHTLINER...
2017 MACK CHU613 TANDEM AXLE SLEEPER (A51222)
2017 MACK CHU613...
WEATHERGUARD TOOLBOX (A50854)
WEATHERGUARD...
