Fan / alternator belt replacement on a TC33D
   / Fan / alternator belt replacement on a TC33D #1
SteveInMD
Platinum Member
Brookeville, MD
TC33D
My fan / alternator belt came apart today. It's not obvious to me how to remove / replace the belt. Does it require removing the radiator and fan? Or does it somehow slip between the fan and fan cowling?
I see the part number for the belt is 301525A1. Does anyone have a cross reference to another brand or auto parts store?
   / Fan / alternator belt replacement on a TC33D #2
Go to the gates or dayco web site.
Unless you have a front mounted pump, it should slip/ work it over the fan blades and into place.
Ds
Thanks. I've got it removed.
   / Fan / alternator belt replacement on a TC33D #4
ff Just changed to belt on my 1920; original belt, 24 years; didn't break but was dry-rotting. Got a new one from the NH dealer at approx $30; got the nos. off the old one , called the local auto parts store and could have had one for approx. $20. oh well.........Loosened the alternator, then slipped the belt off of each blade; tookit off, put the new one n; tightened the alternator, no big deal.
2014 MACK GU713 WATER TRUCK (A51247)
2014 MACK GU713...
UNUSED RAYTREE RMSG29 - 29" STUMP GRINDER (A51248)
UNUSED RAYTREE...
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
UNUSED HURRICANE D6028 JOB BOX (A51248)
UNUSED HURRICANE...
