Falling backhoe in storage
   / Falling backhoe in storage #1
liberty2701
Platinum Member
Lakes region,NH
Kioti Dk50se hst
Is it normal for the backhoe to fall when my Gc2610 is not used for a week. Does this indicate a leak?
   / Falling backhoe in storage #2
Are you talking about the boom (which there is a lock) or the stabilizer (outriggers) legs?
With the outriggers, that is pretty common and I wouldn稚 be too concerned. I used to have a MF 2310 and the way the outriggers were set up, near vertical in up position, it was not a problem, but I believe that was an exception and not the rule. With outriggers on another BH, I just run a ratchet strap from one to the other to keep them in place and take the pressure when not in use.
   / Falling backhoe in storage #3
Yup, if its not locked in place via a pin
   / Falling backhoe in storage #4
Just about all hydraulics leak a tiny bit and eventually leak down. there is no such thing as a perfect, zero leak seal. Leaking down in a week, in my opinion, is nothing to worry about.
2018 INTERNATIONAL LT625 (A53843)
2018 INTERNATIONAL...
Diesel generator crank no start (A51691)
Diesel generator...
2022 CATERPILLAR 299D3 SKID STEER (A51246)
2022 CATERPILLAR...
Tires (A50322)
Tires (A50322)
UNUSED AGT 54" EXCAVATOR HYD BRUSH CUTTER (A51248)
UNUSED AGT 54"...
