Fairly new to tractors, will need to clear land and have questions.
   / Fairly new to tractors, will need to clear land and have questions. #1
Ihcbigjohn
Southeast Texas
None yet
Hello, during my tractor research I kept running across is site, so I thought I would just join and ask my questions here. My wife and I are purchasing 37 acres that has had timber previously harvested off of it. It is regrown with mixed pine, hardwood, and brush, the majority of which is smaller than 4". I have looked at the various land clearing and mulching companies near us and their day rate and production estimates put the bill over $50k to clear it. I have always preferred to just buy a tool or piece of equipment and do it myself and have something to keep after the job is done, and for that kind of money I feel that I can certainly get a decent used machine. Originally I had thought to get a 20-25 ton excavator from auction, put a rake bucket on it and go to town. I would be able to clear the trees, do some minor grading and dirt road work, as well as dig the pond with it. However I also figured that we will need a tractor, and I happened across a newholland ts110 woods boss with a 72"brown tree cutter, and the videos of this setup that I have seen are pretty impressive. My concern is whether or not this tractor would be able to come back and rake out the roots from these 4" and smaller trees. I have read that a dozer is usually better than an tractor at this, but it seems that people are also potentially figuring smaller tractors in this comparison. When I look at drawbar pull ratings of various dozers and the ts110 in the 1-2mph range the tractor seems to be better than most of the smaller dozers. Do you think that the ts110 could get the roots with a rake or 3-5shank subsoiler since the soil is a loam type? How possible/tough is it to come back and add a bucket later since this one doesn't have one? The pictures of the property are what used to be a driveway, and an example of what the rest of the property looks like. I am also including the drawbar info I looked at. Thanks for the input!
   / Fairly new to tractors, will need to clear land and have questions. #2
Around here they'd use a track loader, but what I see is generally 10AC & smaller. You're clearing it all or just a few acres homesite & driveway?
Anyway, track loader/crawler loader similar to a JD 655 or Cat 953 would probably make short work of what you're describing.
Sorry, having trouble getting the pictures to post, I can select but it won't upload. Eventually we would have the whole thing cleared. Probably only 8-10 acres at first, and then the rest over the next few years. Any idea how long it would take small stuff like that to rot down if you just cut it close and left it?
   / Fairly new to tractors, will need to clear land and have questions. #4
A very long time. Walk thru the woods and look at some old moss covered fallen trees..... And then you still have stumps & roots underneath that will be in your way for whatever you do there in the future. You want it cleared by knocking them over & getting the root balls. The track loader can then smooth that out even faster than it cleared it. A good operator with a good sized track loader will clear acres of what you describe in a day. 2 different properties down the road from me were done this past year. Trees were 95% pines, probably none larger than 22" at the base, but several acre lots down to bare smooth dirt in a day or two. The piles burned for a long time afterward......
I'm kind of surprised your estimates are so high. Heavy equipment time must cost a lot more there. I *think* general clearing from a smaller outfit around here is right around $100/hr + transport, generally a 6 hr minimum.
What is typical here is to clear a large area with the track loader, push it all into a huge pile in center of that newly-cleared area & burn it.
I think you have to have a minimum of 5 posts or something to do attachments. Try just putting up a few short posts after this & then see if you can do your picture :)
There is a company just down the road, i.e. Could drive it to my property and not trailer the equipment, that has a Barco 930b. They want $2500/day and said they would average 1.5 acres/day subsoil mulching.
Another wanted $1200/day, but had a skid steer mounted mulcher, so I figured it would take them a lot longer.
CMV, I would have figured that the 1-4" stuff would decompose much faster than bigger stumps.
   / Fairly new to tractors, will need to clear land and have questions. #8
A large front end loader with a root rake, the hardest stump is live pine it goes strait down everything else falls over easily after that run the rake around it, burning with takes days with equipment their to rework the pile. $5/7K to get 7 acres and driveway done.
   / Fairly new to tractors, will need to clear land and have questions. #9
Welcome to TBN John, I think you're on the right track with your thinking although you could accomplish this with a much smaller excavator. (an excavator would be my first choice, particularly if you can burn the wood). A 10 ton machine should easily remove what you've described. I mention this as you will be able to widen your search for the best deal on a machine that you can "get out of" or "flip" after you've gotten your use out of it. Then go tractor shopping :thumbsup:
   / Fairly new to tractors, will need to clear land and have questions. #10
i just had 5 acres cleared on a piece of property i purchased to comply with crp regulations and it cost me about 1100/acre - it was more than 4 in tho in some areas i had some up to 8inch trees it was 11 yr growth mostly soft/silver maple - if its only 4 inch i would lease a mulcher for a month and a skidsteer you could do amazing things with that and give it back - then rent a dozer with a ripper for a month, that will run you around 5K/month for the dozer, 3500 for the skidster/mulcher then you will be ready for a tractor and not have torn up/overused the tractor - you will save plenty of $$ doing it yourself and in a months time you could do that acreage easily with a fecon/skidsteer might not even need that long but im thinkign this is a part time evening/weekend gig so you could bust that out no problem. and you get really great rates on monthly vs weekly rentals
I rented a 250 volvo excavator for a week for 2200 and it was only 5500 for the month so that is what i mean on saving money and using someone elses stuff - i didnt have the time to mess with the 5 acres and the guy was able to knock it out in 2.5days, we needed to get crops in
BESTWAY AG VSK50 LOT NUMBER 103 (A53084)
BESTWAY AG VSK50...
NEW Wolverine 72'' Skid Steer Sickle Bar Mower (A53002)
NEW Wolverine 72''...
2018 Forest River Grey Wolf 26RR Lmtd Toy Hauler (A52384)
2018 Forest River...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2016 Peterbilt 320...
