factory cab ac problem
   / factory cab ac problem #1
lawn_king
Veteran Member
Hanover massachusetts
kubota L 3540 hsdc,B 2320 hsdc & lots of other stuff!
Today the ac started blowing cool and hot air together, i tried multiple settings with the same results. Could this be a ball valve adjustment or should it go to the dealer? 5 weeks left on warranty.
   / factory cab ac problem #2
given that I am a newbie around here, take what I have to say with a grain of salt.
If you have any problems what so ever with the AC and it is in fact operating differently, then without question I would take it to the dealer. At least if there is a problem they can fix it under warranty. If they say that it is behaving normally, then keep your receipt. That way if you have a problem outside of warranty you can bring to their attention that you asked to have it checked and fixed while the unit was still under warranty.
Regards,
Bryan
   / factory cab ac problem #3
Check to make sure that there is not a bunch of dried grass blocking the front radiator on the outside and that the dirt screens inside are clear of air blocking items.....mine did the same thing and I cleared out the mess and all was well.
Jeff
Thankx, i will check it out.
Good call chessie. There was some dry grass,etc, at the very bottom of the radiator. I blew everything out with the compressor & we be cool :cool: Thankx.
(15) TRUSSES - 32" X 12' (A50460)
(15) TRUSSES - 32"...
2014 FREIGHTLINER BUSINESS CLASS M2 SERVICE TRUCK (A50459)
2014 FREIGHTLINER...
2001 GMC C7500 Truck, VIN # 1GDL7H1C21J503200 (A48836)
2001 GMC C7500...
2022 CATERPILLAR 259D3 SKID STEER (A50458)
2022 CATERPILLAR...
2021 CATERPILLAR 302.7CR EXCAVATOR (A50458)
2021 CATERPILLAR...
(4) 8 Lung Dual Wheel and Tires (A48837)
(4) 8 Lung Dual...
