F680 Kohler 20hp wiring
   / F680 Kohler 20hp wiring #1
Bschwei
John Deere F680
I recently pulled the engine to replace the front seal. I thought I had the wiring correct, but after re-conneting the wires to the starter and battery, the battery light stays on and the battery drains and mower quits.
HELP...What wires go where? I have the heavy gauge red wire from battery to the starter going to the (+) terminal. The heavy guage black wire from (-) battery terminal going to the back of the engine, those I'm sure of. Now comes the unknowns.
On the battery side of mower:
1) There are smaller gauge red and a black wires in flexible plastic tubing coming from a head light switch. I think this is an add on! I thought the red went to the starter and blk to battery (-)
2) There is a medium gauge purple wire coming from inside the front of the engine housing and not sure what this connects too...Gnd or starter?
Opposiste of mower:
3) Just below the oil cooler, there is a electrical box that has potting material on one side and cooling fins in the other. It has 2 black wires and 1 purple wire w/ connecter plugs that connect to 2 black wires and one red wire. Do the black go together (and does it matter which ones) and the purple go to the red? I switched the black wires but battery light stayed on.
Thanks in advance for your help.
Bruce
Update: JD informed me to check the voltage rectifier. I have 33v incoming, but only 5v going out. Is this low voltage normal or is this what'ws draining my battery?
2016 Chevrolet Tahoe SUV (A52377)
2016 Chevrolet...
2015 DODGE RAM...
UNUSED IRANCH IRMC HIGH END ELECTRIC MASSAGE CHAIR (A54757)
UNUSED IRANCH IRMC...
2 windsor 351 inboard motors w/transmissions shafts rutters and props (A53424)
2 windsor 351...
2017 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2017 Ford F-350...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2019 FREIGHTLINER...
