F680 excessive vibration ???
   / F680 excessive vibration ??? #1
F680ztrak
John Deere F680 Ztrak
I just purchased an F680 John Deere Ztrak mower that seems to run great, but it has a tremendous amount of vibration from the engine. No smoke and starts right up, but it vibrates more than I think it should. Is this normal for the CH20 Kohler Engines? I believe it is the command series.
The engine vibrates even with the deck turned off and it has me thinking something is out of balance, but I'm not sure what it could be.
Hope you guys have some hints on what to look for! :)
   / F680 excessive vibration ??? #2
Ask your dealer. I think there was something to do with the facing on the flywheel where the driveshaft mounts. But, that would be something that would do it from new. If it just started, check the driveshaft joints and the rest of the driveline for wear.
Thanks I will check! The gentleman I bought the mower from had recently had it rebuilt, so it could have started there.
I will ask a dealer to see if anything could be wrong since the rebuild.
2015 FORD-750 XL SUPER DUTY DUMP TRUCK (A51406)
2015 FORD-750 XL...
2019 KUBOTA SVL95-2S SKID STEER (A52705)
2019 KUBOTA...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55301)
NEW HOLLAND 706 30...
Utility Trailer (A52377)
Utility Trailer...
