F510 oil type for engine and hydro
   / F510 oil type for engine and hydro #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I recently bought a middle 1990's Deere F510 mower with a Kawasaki engine and hydro transmission. An oil change is next and I wonder if I am OK with current SM rated oil in that hydro? It takes 2.2 quarts and that convers both the engine and hydro.
Current oils are lacking in zinc and phosphorus and the owner's manual calls for an SG or SL oil. I think the engine needs it but I'm not sure on the hydo.
Do you suppose I am OK with a newer oil or should I pay extra and get something current like Royal Purple with added zinc and phosphorus content?
Any ideas on this?
   / F510 oil type for engine and hydro #2
Use JD 10W-30 Turf-Gard engine oil.
Well, I guess not so fast.
Went to Deere to pick up some oil and the rating on the Turf Guard was SM, which is the newer grade with the wear additives removed. There was some JD regular Torq-Guard 10w30 oil there with the older SL rating and I wonder if I should go with that?
These newer oils are causing lots of mischief in older engines.
2017 JOHN DEERE Z950M LOT NUMBER 83 (A53084)
2017 JOHN DEERE...
(41) T-POSTS W/ (20) ROLLS OF BARBED WIRE (A54757)
(41) T-POSTS W/...
UNUSED CFG INDUSTRIAL MX15RX EXCAVATOR (A52706)
UNUSED CFG...
1831 (A51247)
1831 (A51247)
2019 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A52377)
2019 Allmand...
