Oil & Fuel F40 leaks gear oil
   / F40 leaks gear oil #1
ScottRFoster
Jacksonville, FL
Ferguson F40
Hi:
I have gear oil puking out a hole in the front of the gear box... see red arrow in attached pic.
Oil is milky and I suspect water intrusion from rotten boots on the shift levers.
Before I replace the oil - does puking from this location indicate a bad seal - if so, what is entailed in the repair?
If not, should I simply replace the boot and replace the gear oil?
Thanks,
Also - is there a pressure relief / breather port I should check to make sure there is no clog?
Thanks,
   / F40 leaks gear oil #3
probably a little late with this reply but i see no one else has replied. yes thse water is getting in around the rubber shift boot. replace the boot however i still don't trust that water won't get in, either cover with a tarp when not in use or set a plastic pail over the gear shift. i don't think there is a pressure relief valve if it's a standard transmission the gears run in the oil and bring it to the top. as far as the leak there should be a seal around the front output shaft on the transmission but if water is leaking in it is also overful. i would try draining and rerfilling with fresh oil first. oil at the proper level may not leak out.
   / F40 leaks gear oil #4
Hi:
Thanks,
There should be a "weep hole" at the bottom of the interface between the block and the bell housing with a cotter key in the weep hole to keep it clear of dirt and bugs , etc. Then any rear main bearing leakage or front input shaft seal leakage will drip underneath and not fill the bellhousing and wet the clutch. Check your tractor for this drain at the bottom. The leakage can either be engine lube oil or transhydraulic fluid. In either case, it will take a split to fix it.
   / F40 leaks gear oil #5
yep.. shifter boots won't do didly for that dry area of the bellhousing. tas said.. there should be a weep hole.. might have a cotter pin in it. drains clutch bellhousing of rear main and trans input shaft seal leaks..
2018 MDB LV600 GREEN CLIMBER SLOPE MOWER (A51406)
2018 MDB LV600...
WESSEX CHT-100R-E LOT IDENTIFIER 46 (A53084)
WESSEX CHT-100R-E...
FRONTIER MG20F LOT IDENTIFIER 22 (A53084)
FRONTIER MG20F LOT...
2013 Club Car Carryall 252 Electric Utility Cart (A51694)
2013 Club Car...
2025 IR UNUSED Ripper (A53117)
2025 IR UNUSED...
UNUSED KIVEL 3500# PALLET FORKS (A51248)
UNUSED KIVEL 3500#...
