F350 V 10
   / F350 V 10 #1
unreconstructed
Platinum Member
West Texas
JD 5325 JD 5203 JD 2320 LT 133
Finally got my 08 F350 (2WD) with V10 which I ordered in mid-August. Towed my Jd 5203 with FEL to my place over Thanksgiving. The V10 did everything I expected it to do --I replaced my F250 with 5.4 with the 350.
Mileage was about 9 towing and 12 1/2 without a load on the highway. Have read reports of the V10 making 15 mpg highway on a good day. Don't know that I will pick up much more mileage after putting on a few more miles. Will add a K&N after warranty expires.
Any feedback from V-10 owners?
NOTE: not trying to get into a diesel vs gasser debate..
   / F350 V 10 #2
I had 2000, 2003, F350s 4wd CC SRW with V10s. I now have 2006 but an F250. Gas mileage towing was very similar with 10000lb 2 axle bumper pull trailer. Non towing mileage about 11 combined city/hwy driving. Only got 14 once when on highway running about 72 mph with big tail wind. Just weighed it the other day empty with 1/2 tank fuel and was 7600lbs with no driver or passengers.
I love my truck. Tows great and lots of room.
   / F350 V 10 #3
I purchased a 2008 F250 CC 4x4 Lariat with the V10 and just love it. I looked all over for a V10 and finally the dealer had to drive 350 miles (one way) to pick one up at another dealer out of state. Traded in an 05 6.0L oil burner and am very satisifed with the change. After doing lots of research, I just couldn't spend the extra $6K just to get the 6.4L desiel especially after the reduction in MPG going from the 6.0L to the 6.4L. Plus all of the new desiel emission requirements will eventually add to more costs down the road. I don't tow a whole lot so it was the right choice for me.
I've got 2K miles on her now and averages about 12.5 MPG on the HWY. Over time that is supposed to go up a bit once the motor breaks in, etc.
   / F350 V 10 #4
Great to hear some actual numbers. I get tired of hearing how so and so gets 30 mpg with his motor or so and so gets 35 with his brands motor:rolleyes:
I get around 16mpg with my 06 F250 with 6.0 and that is just normal local driving. I never clocked it while towing. Our 4.6 and 5.4's get around 10-14 depending on what tools are in them. I think our next truck will have the V10 and while I like my 6.0 I do not need two diesel trucks at one time as the rest of our towing on a normal basis it light duty towing of 2-3 tons.
   / F350 V 10 #5
I have a 1999 V10 F250. Yours is about 75 more hp and 3 valve design instead of my 2 valve design. The early ones had some issues with blowing out spark plugs if not torqued tight enough. I have not had that problem. The V10 has been an otherwise extremely reliable engine for Ford. I make about 9-10 with fairly heavy load. 12mph empty at 65-70mph. My all time worst mph was about 5-6 mph pulling, tall, heavy load at 65-70 mph with 25-30 mph headwind. For me, wind resistance will hurt fuel mileage much more than weight of load. I use mine about 80% of the time pulling some type of trailer.
I think about getting a newer model but this one has had almost 0 problems. My next one might be a diesel, but a gasser is probably the most logical choice for my use.
   / F350 V 10 #6
I think you are right in the ball park for that rig. All the guys with them get 12-14 mpg empty. Most don't pull much and they get the same pulling small trailers (snow mobile, ATV, Boat, etc). There really isn't any way you will get much more mpg with that truck as it is tall, broad and heavy. But hey, it's a TRUCK.
Most of the guys have bought a 2nd or even a 3rd time with the V10 and like them all lot. One went from a V10 to a 5.4 and LOST mpg. Not a happy camper, but he has no patience and jumps the loud peddle expecting V10 torque.
Enjoy the ride,
jb
   / F350 V 10 #7
Be glad that you got the V10 in the Ford's in the 08's I know of a lot of people that have traded in due to the gas mileage in the 08 diesel's from Ford. There was a F250 that someone I know had it was getting between 4.5 and 6.0 MPG when driven in city traffic and the highway, this is not a good thing!
   / F350 V 10 #8
My 1999 F-250 XLT Super Duty 4 x 4 has a super cab, long bed, V-10, 5-speed manual, 4.11 limited slip rear end and I get an average of 13.5 MPG from it. I get 450 miles on a tank of gas. I don't tow often; but when I do the V-10 has served my needs just fine, though I don't have any towing MPG figures. The largest thing I've towed is a mini excavator from the rental yard.
I would like a set of headers, cat-back exhaust and a K & N style oil-less air intake system for it.
I've been quite pleased with the engine, and at the time I ordered it, it was 10% the cost of the 7.3L diesel.
My only gripe with the truck is there is a sour spot at 65 MPH where the cab noise is quite loud. I attribute this to a combination of engine and drivetrain harmonics.
I'm noticing more and more V-10's in newer Super Duty's around here and I'm wondering if that's due to the added cost of the 6.4L engine and the lower MPG due to the modern emissions hardware. I had my truck in for routine maintenance at the local Ford dealer and I saw that diesel oil and filter changes were in the $100+/- range depending on engine displacement.
   / F350 V 10 #9
If you're getting that kind of mileage then you've got a sick truck. The emissions equipment has definately hurt mileage but not that bad. My '08 F-450 has only 1600 miles but so far it's gotten a high of 15 highway and 12 city driving. That's with a 4.30 axle ratio and a 8900# truck. You do have to keep your speed down, these trucks are as aerodynamic as a brick. The mileage on all the new diesels have been hurt by the emission equipment.
The V-10 is supposed to be a bulletproof engine. I've never heard of anyone having a major problem with one. They make a lot of sense in an F-250/350 SRW pickup.
   / F350 V 10 #10
I special ordered my Y2K CC Dually with the V-10. It has continually delivered 12-13 mpg when not towing. The worst that I have gotten was just over 8mpg towing a sprint car from Florida to Iowa at 80+ mph. It has plenty of torque for towing and a lot more pleasant that a diesel to own.
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A52748)
2012 JOHN DEERE...
2006 HEIL MC407 (A52472)
2006 HEIL MC407...
1997 JOHN DEERE 544G WHEEL LOADER (A52472)
1997 JOHN DEERE...
2005 Chevrolet Uplander Van (A51694)
2005 Chevrolet...
2005 Toyota Tundra Limited Crew Cab Pickup Truck (A51692)
2005 Toyota Tundra...
2020 Chevrolet Tahoe SUV (A51694)
2020 Chevrolet...
